Landartma Posted March 16, 2021 Share Posted March 16, 2021 Any ideas why my viewport is so blurred? My 3d looks great then once I open it in viewport and select Isometric it goes all blurry. Quote Link to comment
0 Pat Stanford Posted March 16, 2021 Share Posted March 16, 2021 Check in the Organization Palette that the Sheet Layer DPI is set to something greater than the default 72 DPI. I personally find 150 sufficient, but there are others here who prefer 300 or even 600. Just remember the higher the DPI the longer renders will take. 300 takes 4 times longer than 150. 600 takes 16 times longer than 150. If you are doing test renders you are often better off setting the DPI down to something low so you can adjust and get the lighting to cast the shadows where you want and then turn up the DPI for final renders. 3 Quote Link to comment
0 Zach S Posted November 8, 2023 Share Posted November 8, 2023 2024 Version and I can't get the blurriness to stop. I put DPI at 150, 300, 600 and even 1000 and it still looks blurry. WHY is this such an issue??????????????????? People have been asking/ complaining about this since 2017. Should I try AutoCad? Quote Link to comment
0 Pat Stanford Posted November 8, 2023 Share Posted November 8, 2023 Tell us more about what you are seeing and what you have tried. Is the blurriness on screen or in your prints or PDFs? Is this from Sheet Layers or Design Layers? What hardware and operating system? Quote Link to comment
0 Elite Exhibits Posted November 8, 2023 Share Posted November 8, 2023 @Zach S @Landartma what are the Rendering Settings for a selected Viewport in the Object Info Palette (OIP) ? see attached Peter Rendering Settings in a Viewport.pdf Quote Link to comment
0 Vectorworks, Inc Employee jcogdell Posted November 9, 2023 Vectorworks, Inc Employee Share Posted November 9, 2023 @Zach S Have you used a renderworks camera to create the viewport? A range of new cmaera effects and controlls have been added in 2024 and this may be causing the blurriness. Quote Link to comment
0 Vectorworks, Inc Employee TomWhiteLight Posted November 9, 2023 Vectorworks, Inc Employee Share Posted November 9, 2023 Can you post the file? Quote Link to comment
Landartma
6 answers to this question
