Setup assistant problem
PROCESSOR= 533SYSTEM = OS9.2.2RAM= 640VW ArciLand 9.5 & 9.5.1VWLandmnark 9.5
When I create a new document using Setup Assistant (SA). SA work fine for the the during the setup but when you go back into SA to add more sheets I get the following
Error: Setup Assistant must be run on a Steup Assistant Template or templates/Documents derived from the Setup Assistant Template.
does anybody know what may be casing this?
Here's a recent post from a related forum, just below:
Hi Andrew,you can run the SA as many time as you like. Just make sure in the Auxiliary Sheets dialog, that you reset the number of sheets to 1 less than it is displaying and click the "Apply" button. An extra step(s), but workable. This bug has been around for a while and unfortunately hasn't seem to have received attention yet. Hope that helps.
Peter HugginsIN MEDIAS RESpete@inmediasres.net
