AndyLowe
Spotlight Lighting Pipe Tool - length stuck
Hi all
Wondering if someone can advise me? I'm using Spotlight 2021 and having a problem with the lighting pipe tool. It stuck at a fixed length of 4.537" for a reason I can't figure out. No mater what size pipe I try to draw, that's the length the pipes are stuck to being. And these tiny pipes don't look like the normal scaffold pipes ... just a tiny straight line with a couple of markers on them.
Any advice would be really appreciated as I can figure out what I've clicked to makes his happen.
Thanks and best wishes
Andy Lowe
Do you have a "Style" selected when using the Pipe tool.
If you're using Line insertion mode and have "Unstyled" within the dropdown menu you should be able to change the size of the pipe then set your Object Properties
M
Thanks Michael. That worked. It was also the Lint Type was set to single rather than double that confused me.
Thanks so much!
