  • 11
Fix Workspaces. Make it useful, not miserable.
Bruce Kieffer
I've commented before how bad the workspace interface is. Please fix it. Heaven forbid you accidentally undock or move a palette and you want to return it to the location it was previously. Nope. Try to save a copy of your workspace you like so you can reuse that, but never try to overwrite it with another copy named the same. That does not work.
None of it makes sense. Why am I saving a workspace when saving it does nothing. I can't revert, so why save?
  • Like 3
12 answers to this question
I spend hours every week trying to locate and reattach palettes, that have been accidentally torn off and moved, because that is what they do all of the time, and they cannot be locked down.
And I do not even have palsy!
I never heard of anyone who use this 'feature'  for its misconceived purpose, so why is it still here?
At least provide us with an off-switch, please.
Hey folks, please upvote this using the arrow at the top left.
OMG, yes when a palette seemingly undocks itself, and this happens, especially on the right side, then trying to redock it on the left is crazy and mysterious. Point being, if saved workspaces worked as I think most of us think they should work, then reverting to the previous saved setting would solve the problem.
I recall trying the "Save Palette Positions" in the past and then resetting them in the preferences session tab, and back then it caused a huge mess. I just tested that again on a copy of my workspace and it seems to work, but there's nothing intuitive about that "workaround."
https://app-help.vectorworks.net/2018/eng/VW2018_Guide/Start/Saving_Palette_Positions_and_Settings.htm
The action required to undock and float a palette. As I understand it an accidental click while the mouse was moving over a palette tab could cause an undock. The action required is supposedly more definitive. I have never had the problem, but the beta testers who helped track down the issue seem to think it is a substantial improvement.
11 minutes ago, line-weight said:
What's changed in SP3?
I think the recent change was related only to the new 2021 ability to separate individual tabs of the Navigation, Object Info, and Visualization Palettes. It doesn't happen so easily anymore and requires a deliberate click-hold-drag. I've found it much improved.
I don't think there was any change regarding accidentally undocking entire palettes though.
Ah, cheers. I will look out for that. It's certainly long been annoying that I can accidentally undock a palette (or accidentally close it). I'll keep an eye out for this change.
Hello
I spent a lot of time trying to fix the problem of tool pallets that changed places unexpectedly, especially in multi-screen configuration.
The hotline made me make a number of tweaks without success.
Finally, I found a utility (under Windows) called Display Fusion that can recall the position of windows and pallets on multiple screens.
This requires some tweaks and hacks (with Edgar Ramel's view control pallets specifically).
But now, a key F20 or extension/restore of the application window and everything ends up where I want and how I want.
It saved me time and saved my nerves (but as there are fortunately plenty of other topics of annoyance with VW ... my nerves are still strained enough 🤪).
Hoping it serves Windows users.
Kind regards.
Edgar
