Nebeor
How can i intersect a 3D object with a plane and get a 2D polygon in return?
A simple example: how can I turn this in an 2D oval shape that corresponds with the intersection, just by using code?
Posted (edited)
@PeterYip Very cool video, but I still need to find a way to do "Extract" through the SDK.
Also, I still need to convert it afterwards from a nurbs to a 2DPolygon.
Edited by Nebeor
Any shape or particular shapes? You can use ISDK::CreateContourCurves() to get the NURBS intersection and then ISDK::ConvertNurbsToPolylineArcs()
If I know the shapes (I do a lot of intersecting cones and planes), I just do the math.
  • Love 1
@JBenghiat Awesome! that was just what I needed, I don't even have to draw a plane or extrusion. I've put the 'delta' param of Create Contour curves to something insanely big, otherwise it will crash on conversion.
You can also pass 0 to the delta, which should only give you a contour at the cut plane and effectively give you the same result.
