VulcanGrip
9.5 will not open
I downloaded VW 9.5, and when I try to open, I get, "MSL C++.PPC.DLL Rel" could not be found. Anyone know what this means??
Generaly, this error occurs because you have placed the RenderWorks library file in your Extensions folder.
The RenderWorks library is not a system extension. Move it back to the VectorWorks folder and everything should be fixed. You may have to restart as well.
Matthew GiampapaNNA Technical Support
Yes, you were right. I got 9.5 to open but RW is not installed. I have RW 9.01 installed. And the 9.5 updater says it updateing but its not there when opening file...
Ugg, this bites it...
Makes me 'almost' wish we were back in the 'lead drafts' world. rolleyes.gif" border="0
VulcanGrip,
If the RenderWorks Library file was not in the right place when you updated to 9.5.0 (or 9.5.0 -> 9.5.1 for that matter) The updater wil skip the RenderWorks part of the update. Since the updater is applying changes to an existing file, not replacing the file with a new one, everything needs to be in the right space to work.
If your 9.0.1 install is working properly with RenderWorks now, you can just re-run the updater. If your 9.0.1 doesnt have RenderWorks working, reinstall from the 9.0.1 RenderWorks CD and then run the 9.5.0 updater.
