vs.GetSpaceNameForObj/vs.GetSpaceNumForObj
Hi,
we still are working again on Secondlevel Space Boundaries for Space Objects. (
However I think about solving the issue with a Python-script. In Worksheets there exists the function GetSpaceNameForObj and GetSpaceNumForObj.
I have been looking for it in the Vectorscript/Python function reference, without any success...
Quote
SpaceName = vs.GetSpaceNameForObj(HNDL)
SpaceNum = vs.GetSpaceNumForObj(HNDL)
obviously don't exist.
Guess the commands only exist for Worksheets, right? Is there any possibility to coordinate an object to the adjacent space object?
@matteoluigi ,
   Have you tried querying the PIO record for the name and number?
SpaceName = vs.GetRField(vs.FSActLayer(), 'Space', 'Name')
SpaceNum = int(vs.GetRField(vs.FSActLayer(), 'Space', 'Number'))
And if you need it,
SpaceArea = vs.Str2Num(vs.GetRField(vs.FSActLayer(), 'Space', 'Area'))
HTH,
Raymond
nope, sorry but both worksheet functions don't check the name or number of a selected space but they get me the name or number of a space the selected object is situated in.
For example GetSpaceNameForObj can get me Name and Number of the space-object a selected furniture-symbol is planned in.
Pity, that the function obviously only works in worksheets, not in Vectorsript/Python
@matteoluigi ,
   Sorry, I misunderstood the question and the nature of the WS functions. Here is a short Pascal script, lightly tested,  that searches every Space object in the drawing and tests if the object passed to the function is inside any Space. Now the functions I posted earlier will return the correct results AFTER the new function is called which returns the appropriate Space handle.
   It shouldn't be too hard to Pythonize the script. As a simplification, I am using the center point of the referenced object to make the test, and not testing the object's bounding box. Feel free to modify this to your heart's content.
PROCEDURE xxx;
{ Script to test the ObjInSpace function. }
{ 14 Mar 2021 - Raymond Mullin }
VAR
	H0, SpaceH :Handle;
	SpaceNum :Integer;
	SpaceName :String;
	function ObjInSpace(H :Handle) :Handle;
	{ Return a handle to the Space object that contaons object H, or NIL if none is found. }
	Var
		SpaceH :Handle;
		X, Y :Real;
		procedure InSpace(SpcH :Handle);
		Var
			RecH, PolyH :Handle;
		Begin
			RecH := GetParametricRecord(SpcH);
			if (RecH <> nil) & (GetName(RecH) = 'Space') then begin
				PolyH := Space_GetGrossPoly(SpcH);
				if PtInPoly(X, Y, PolyH) then
					SpaceH := SpcH;
			end;		{ if }
		End;		{ InSpace }
	Begin		{ ObjInSpace }
		hCenter(H, X, Y);
		SpaceH := nil;
		ForEachObject(InSpace, T=86);
		ObjInSpace := SpaceH;
	End;		{ ObjInSpace }
BEGIN
	H0 := FSActLayer;
	SpaceH := ObjInSpace(H0);
	if (SpaceH <> nil) then begin
		SpaceName := GetRField(SpaceH, 'Space', 'Name');
		SpaceNum := Str2Num(GetRField(SpaceH, 'Space', 'Number'));
		message(SpaceName, '  ', SpaceNum);
	end		{ if }
	else message('Selected object is not contained in any Space objects in the drawing.');
	SysBeep;
END;
Run(xxx);
HTH,
Raymond
Posted (edited)
Quote
def ObjInSpace(SpaceH):
             def InSpace(SpcH):
                          RecH = vs.GetParametricRecord(SpcH)
                          RecHN = vs.GetName(RecH)
                          if ((RecH !=  '') & (RechN == 'Space')):
                                       PolyH = vs.Space_GetGrossPoly(SpcH)
                          if vs.PtInPoly(X, Y, PolyH):
                                       SpaceH = SpcH
             X,Y=vs.HCenter(SpaceH)
             SpaceH = ''
             vs.ForEachObject(InSpace, 'T=86')
             ObjInSpace = SpaceH
H0 = vs.FSActLayer()
SpaceH = ObjInSpace(H0)
if (SpaceH !=  ''):
             SpaceName = vs.GetRField(SpaceH, 'Space', 'Name')
             SpaceNum = vs.Str2Num(vs.GetRField(SpaceH, 'Space', 'Number'))
             vs.AlrtDialog(vs.Concat(SpaceName, '  ', SpaceNum))
if (SpaceH ==  ''):
             vs.AlrtDialog('Selected object is not contained in any Space objects in the drawing.')
I tried to pythonize it, but it won't work to the end 😉 what's wrong?
The compiler says:
Traceback (most recent call last):
"File "<string>", line 11, in InSpace
NameError: name 'Rechn' is not defined
Edited by matteoluigi
The variable in Raymonds script it RecH (Record Handle).  If the error message actually says Rechn, then you have a typo or have changed the variable name.
And Python cares about capitalization (IMNSHO a really stupid thing to do in a programming language.) The last line of your quote shows RecHN. The error message says Rechn.  I believe those would be considered different variables.
That is part of why I am sticking to Pascal as long (or longer) than possible.
Hello @matteoluigi
   Pat's right, there is a typo.
should read:
                          if ((RecH !=  '') & (RecHN == 'Space')):
HTH,
Raymond
Edited by MullinRJ
On 3/20/2021 at 12:08 AM, MullinRJ said:
RecHN
thanks for helping an old myopic man by correcting his simple syntax-errors 😉
However, I still don't understand various things and so I don't get to pythonize the code that easily :
1) I try to call the function "ObjInSpace" with the command "SpaceH = ObjInSpace(H0)". In my opinion I give over the Handle of the previously selected Object H0 = vs.FSActLayer() to the function that way. (that's what you intended to do)
2) however you start the function wit the command "function ObjInSpace(H :Handle) :Handle" is my variant right: def ObjInSpace(SpaceH):? Imo, SpaceH is the "key Handle" in the "ObjInSpace"-function, so, I chose "SpaceH" and not "H" as Handle
however, the Handle "H" never gets mentioned in your whole code. Why? (and, however, your Code WORKS. I already tested it.)
3) if (SpaceH !=  ''):  is the right correspondent code to if (SpaceH <> nil) then begin in Pascal, right? ('' of course are 2 single quotation marks 😉)
then still I'm not 100% sure if the sequence of my code is ok that way, although it definitely is the same as in other Python scripts, where I called a "foreach"-function...
It just feels a little strange first writing the function and then the main program. So you did with the foreach-"subfunction" in your code as well.
It's like:
             def InSpace(SpcH):
                    def InSpace-Code
             def ObjInSpace-Code
Main Code
right?
Sorry for my complex questions, I don't have the time for controlling my code more accurately at work and at home, too.
@matteoluigi ,
   Try this Python conversion. I used your PON='Space' suggestion for the criteria, since it simplifies the runtime. Also note that you have to declare SpaceH as a global variable, since it cannot be passed in the function's calling parameter list. This may be why it wasn't working for you.
import vs
# Script to test the ObjInSpace function.
# 14 Mar 2021 - Raymond Mullin
# GOLBALS
NIL = vs.Handle()		# constant for readability
SpaceH = NIL			# initialize variable
def ObjInSpace(H1):
# Return a handle to the Space object that contaons object H, or NIL if none is found.
	def InSpace(SpcH):
		global SpaceH
		if (RecH != NIL):
				SpaceH = SpcH
	X, Y = vs.HCenter(H1)
	vs.ForEachObject(InSpace, "PON='Space'")
	return SpaceH
if (SpaceH != NIL):
	SpaceNum = int(vs.Str2Num(vs.GetRField(SpaceH, 'Space', 'Number')))
	vs.Message(SpaceName, '  ', SpaceNum)
else:
	vs.Message('Selected object is not contained in any Space objects in the drawing.')
vs.SysBeep()
HTH,
Raymond
