Batch Export
MikeN
You might be able to batch export using an AppleScript calling a VectorScript which has the "DoMenuTextByName" procedure... I really don't know. The easiest way might be to use QuicKeys to call the dialogs, etc.
The print sheets command will print the sheets you have set up one by one. Basically it just activates a sheet and then calls up the print dialog.
quote:
Originally posted by mnelson:
Is it possible to batch export VW files as you would use the 'Print Sheets' command?
If you mean batch DXF export, it's on our wish list. The AppleScript approach might work.
