David Poiron Posted March 11, 2021 Share Posted March 11, 2021 Is there a way to attach a record format to a wall to other styled object so that the record format field entry is persistent (same) for all instances of the styled object? Quote Link to comment
Pat Stanford Posted March 11, 2021 Share Posted March 11, 2021 Unfortunately No. Once a symbol or object is created from a definition that has a record attached, there is no longer any link between the information attached to the definition and the information attached to the object. Each instance of a Record is separate and can be changed individually without effect any other instance. The best work arounds are either a script that will repopulate each instance with the same data, or a worksheet where you can see all of the records and edit the data so it is the same. Quote Link to comment
