Design Layers
GailC
Why do all design layers change to the same view whether top/plan view or front view? If I want both design layers on, but one in top/plan view and the other in front view, how does that work? This just started happening today, so not sure if there's an update that needs to be downloaded.
Ok I figured it out. I clicked on "unified view" in the tool bar at the top.  All better now!  Haha!
Edited by GailC
Figured it out
1 answer to this question
Design Layers in different views works fine, but you have to remember that if you need rendered view, that "Design Layers Render to Infinity". That means that if you render the layer highest in the stacking order when rendered will hide everything on the layers lower in the stacking order.
This is what Sheet Layers and Viewports are designed to overcome.
