markdd 767 Posted March 6 More thinking about a way of not using the Wall tools at all. Quote Share this post Link to post
Landartma 17 Posted March 6 Mark you used and extrude correct? Can that be turned into a wall style? I didn't think that possible. Quote Share this post Link to post
markdd 767 Posted March 6 56 minutes ago, Landartma said: Mark you used and extrude correct? Can that be turned into a wall style? I didn't think that possible. It’s not. I’m just wondering what the simplest most elegant solution would be. 1 Quote Share this post Link to post
Tom W. 335 Posted March 6 @markdd have you tried 5' vertical seam surface hatch on curved extrude? Results not great. I'm glad I never have to do curved walls! 2 Quote Share this post Link to post
markdd 767 Posted March 6 I just did! It’s a shame it doesn’t work either. Strikes me, that’s exactly what they should be used for. I think it works in openGL though.. need to check. Certainly results look about right. I feel another bug report coming on! 1 Quote Share this post Link to post
Tom W. 335 Posted March 6 Ha ha! Hidden Line is a pain When you say you think it works in OpenGL I wasn't sure what you meant... But it got me thinking about how you'd represent a vertical seam in a texture. So I played around with the 'Edit Texture' settings + using the 'Tile' color shader came up with this: A bit hit + miss + not very precise geometrically. Are there other options? Out of interest @markdd have you ever made your own texture from a photo you took? I'd be interested in creating my own brick/stone textures as I've yet to find anything online representative of the types of walls we have here in Norfolk. Is it worth having a go? Quote Share this post Link to post
Tom W. 335 Posted March 7 For what it's worth this is a plywood stud Wall Style with the metal sheets as individual 2mm thk extrudes with 2mm gaps between them 1 Quote Share this post Link to post
Mark Aceto 453 Posted March 8 On 3/5/2021 at 11:25 PM, Tom W. said: Is the upside-down channel over the panels for lighting? Will that need bending to the shape of the wall?! Cool! Oh, indeed. On 3/5/2021 at 11:25 PM, Tom W. said: Is this in a house? No, retail. Quote Share this post Link to post
Mark Aceto 453 Posted March 8 On 3/6/2021 at 9:32 AM, Landartma said: Mark you used and extrude correct? Can that be turned into a wall style? I didn't think that possible. I modified a wall style for the traditional wall components, and then the extrudes are separate from that. The 2D arc's are guides I used to manually input and measure 5' along the arc length. This was the most painful part, especially if there's a revision... Quote Share this post Link to post
Mark Aceto 453 Posted March 8 Inserting this door where the round walls "join" is going to be my next battle. From what I can tell, the door needs to be inserted on either side of that "joint". Quote Share this post Link to post
line-weight 859 Posted March 8 Another reason why I abandon walls at the first sight of things getting complicated, and spend my time modelling stuff directly instead of fighting the wall tool. You can see it's also inserted the jambs parallel to the centreline of the door rather than perpendicular to the wall faces. Maybe you'd choose to do that sometimes, but not necessarily. 1 Quote Share this post Link to post
Mark Aceto 453 Posted March 9 19 hours ago, line-weight said: You can see it's also inserted the jambs parallel to the centreline of the door rather than perpendicular to the wall faces. Maybe you'd choose to do that sometimes, but not necessarily. I'm not sure how perpendicular to the wall arc would work in real life. Seems like the jamb would either be too wide in the center to stop the leaf from swinging or too narrow on the other side to allow the leaf to close. Quote Share this post Link to post
Tom W. 335 Posted March 9 I think you should go for curved pocket doors 😁 1 Quote Share this post Link to post
Kevin K 182 Posted March 9 @Tom W. Great thought !,.......a mere 10,000.00 per door!! 🙂 1 Quote Share this post Link to post
line-weight 859 Posted March 9 (edited) 5 hours ago, Mark Aceto said: I'm not sure how perpendicular to the wall arc would work in real life. Seems like the jamb would either be too wide in the center to stop the leaf from swinging or too narrow on the other side to allow the leaf to close. The immediate frame and stop would need to be perpendicular to the door leaf but you might want the casing/framing to the wall opening to be perpendicular to the wall faces. Something like what's illustrated here http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/10/Window-Macros/DoorThresholdTrim.html and the equivalent for windows here http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/11/Window-Macros/CavityClosure.html (there are some tantalising illustrations of Archicad apparently doing what VW is absolutely hopeless at... inserting doors and windows into walls in a way that bears some resemblance to real world construction) Edited March 9 by line-weight 2 Quote Share this post Link to post
Mark Aceto 453 Posted March 9 @line-weight wow, those details are exquisite! I'm ruined! Is your solution to extrude / model all of that stuff, use another app, or... ? Quote Share this post Link to post
zoomer 1,134 Posted March 9 50 minutes ago, Mark Aceto said: Is your solution to use another app, or... ? Looks like that is what Archicad can do ... Quote Share this post Link to post
line-weight 859 Posted March 10 (edited) 14 hours ago, Mark Aceto said: @line-weight wow, those details are exquisite! I'm ruined! Is your solution to extrude / model all of that stuff, use another app, or... ? I think if I was drawing a door opening in a curved wall in any kind of detail then yes I'd model it all probably including the wall itself, because I don't think there would be any other option. If it's the case that Archicad can generate all those opening details parametrically then it just shows how far behind Vectorworks is. And it certainly makes me wonder why I've just paid VW going on for a month's worth of income to upgrade my licence to a version that still hasn't fixed any of this kind of stuff at all. The ones on the Archicad pages look like they are mainly showing openings in masonry walls. And anyone who put a bit of thought into how an opening would be made into a masonry wall would realise that because you are building the wall from units with 90 degree corners, that's one reason that at least part of the opening would be formed perpendicular to the wall face. But the VW tools are barely related to constructional reality. Edited March 10 by line-weight 2 Quote Share this post Link to post
Tom W. 335 Posted March 10 (edited) I agree with @line-weight. There is a real problem with the difference between the way doors/windows display in 2D + the way they display in 3D. In the example here, you can create a custom door symbol that incorporates a wall hole component that will clip the wall to the desired shape (i.e. with the reveals perpendicular to the curve of the wall rather than perpendicular to the door) + it will look the way you want it in 3D. But there is no way to have the walls display anything other than square to the door in Top/Plan. I even tried using 'Create Wall Recess' instead of the wall hole component to clip the hole in the wall (as this would have shown up in Top/Plan) but in curved walls it just crashed VW every time I tried! So to achieve the kinds of 2D details in curved walls as shown in the Archicad screenshots you'd have to model the wall as well as the door, rather than use the wall tool. 3D: Horizontal section: Top/Plan: Edited March 10 by Tom W. 2 Quote Share this post Link to post
Mark Aceto 453 Posted March 10 Sounds like the Round Wall tool needs Round Door and Round Window tools... 2 Quote Share this post Link to post
