KevinTK 0 Posted March 5 here is my offline update script: "/Applications/Vectorworks 2021/Vectorworks 2021 Updater.app/Contents/Resources/cli.sh" -S <mylicenseserial> -I "/Applications/Vectorworks 2021" update -i "/Users/<myusername>/Desktop/generic-OZ-SP2.1-darwin.vwupdate" and i got this message: "The update location 'file:///Users/<myusername>/Library/Application%20Support/Vectorworks/2021/' does not exist. To correct this please run this again with the arguments -L userFolder:<path> with <path> being the correct directory, or contact support" what was wrong with my script? in general, how should the -L ---locations <name:path> option be used? can you give an example? Quote Share this post Link to post
Pat Stanford 1,631 Posted March 5 First, does your script actually say <myusername>? If so that is at least part of your problem. It should use the text of your user name instead. Second, is the updater actually on your Desktop? Seems kind of odd, but if you put it there then that is where it is. I have never used the offline updater, so I can't really comment more. Quote Share this post Link to post
KevinTK 0 Posted March 5 Hi Pat. Thanks for the feedback. of course not. I'm just trying to be generic. Apart from that, did you see any other problem with my script? Also, I can't find any kb docs on VW2021 offline update. Is there one available? Quote Share this post Link to post
Pat Stanford 1,631 Posted March 5 I think it should be the same as the 2019 version. Quote Share this post Link to post
KevinTK 0 Posted March 5 Unfortunately it is slightly different. there is this -L option which is not in the 2019 version. here is the list of options: Usage: Vectorworks 2021 Updater [options] [command] Options: -v, --version output the version number -I, --installdir <installation directory> Set the installation directory instead of pulling it automatically -S, --serial <serial> Set the serial number explicitly instead of pulling it automatically -L, --locations <name:path> Set the update locations instead of pulling them automatically. The format should be a comma separated list of location key:path The error I got seems to have originated from not using the -L option. But I don't even know what the -L option is for and how to use it. Quote Share this post Link to post
Tim Ardoin 25 Posted March 5 Hi @KevinTK I've been working indirectly with you through Julian but Juan pointed me to this thread so let me start here. Since you put the install path in quotes, but it's embedding a slash in there for some reason, it seems likely that this is a bug which I'll try to get fixed and updated today. However, one thing you might try, which would also be easier unless you have a bunch of machines you're trying to update all at once via the command line: There's a menu command to apply an offline update. If you launch the updater GUI, there's an "Offline Update" item under Advanced Options. This may very well have the same bug as the command line, but it might work, and it might be easier to use if you're updating installations manually. Another potential workaround would be to temporarily remove the space from the Vectorworks folder, apply the update, and then rename it back. Either way I'll respond when I have more info about what's going on with that path. I think you're doing it right though. 3 Quote Share this post Link to post
KevinTK 0 Posted March 8 Hi all. really appreciate all the response and help. Yes, I've made known to Julian that I will be updating a bunch of machines. So, the script is an essential tool for me. Looking forward to the fix! Quote Share this post Link to post
Tim Ardoin 25 Posted March 8 Hey @KevinTK - So I misread some of the above and what's happening is it's failing to find your user folder. This is either just not there, or more likely, it's in an unexpected location and the logic it's using to figure this out is not complete. So if you could detail where your user folder is and how you set the plists when you install, that could help improve things. It currently looks in ~/Library/Preferences/net.nemetschek.vectorworks.2021.plist under the key NNA User Folder to find the location. So if this points somewhere that doesn't exist, you may see the error. Regardless, if you know the user folder location you can pass it using -L much like the updater suggests. In this case: "/Applications/Vectorworks 2021/Vectorworks 2021 Updater.app/Contents/Resources/cli.sh" -S <mylicenseserial> -I "/Applications/Vectorworks 2021" -L "userFolder:/path/to/user/folder" update -i "/Users/<myusername>/Desktop/generic-OZ-SP2.1-darwin.vwupdate" I'm pretty sure that's the correct quoting on that. The -L option allows you to specify an update location when the updater can't figure it out. The updater often needs to update files outside of the installation folder. For example, Vision items go in the Common folder. Other items may go in the user folder. So it tries to locate these on launch. Let me know if the above command line works, and if you can outline how the user folder may be different from the default, in case we need to add additional handling to find it. Thanks and best regards, Tim 1 Quote Share this post Link to post
KevinTK 0 Posted March 11 Thanks Tim. Much appreciated. A few observations: - Update cannot be deployed from root - Doesn't work if VW2021 app have not been opened before. e.g. I can't use a new admin account to deploy update even though another user have been using it for a while. Can these be considered feature requests for future versions? Would documentation be released in future? Quote Share this post Link to post
