Pinned to Z 0
One of the reoccurring issues I have is with Site Modifiers, Hardscapes, Stake Objects and Grade Settings on objects pinning to the zero plane.  It looks like a matter of accuracy when applying the modifier.  How do you determine exactly what the source of the issue is here.  In this case I am trying to regrade the site using Edit Proposed Site Contours mode both site model contour mode and reshape mode.  keep getting these projections of grade from finished to 0 or in one case 2.33'.  Insights anyone?  Also excuse if my terminology is incorrect.  I'm figuring out how to do the grading.
Looks like you have an object at zero. Depends on what that object is and how it was placed. let me know what that object is.
That's my issue I can't tell.  I started to play around with regrading the site and running topo lines into my wall.  When I hit exit proposed site model contours the whole thing goes crazy.  I'm thinking I am clicking on geometry on my 0 plane.  OIP says its the site model at 0 elevation.  Any idea how it might have gotten to zero and should it even snap to zero my minimum elevation setting is 95'10" with a datum elevation of 2'.
