Moving Doors (vertically)
How can you move a door vertically on a wall. Occasionaly it is easier to make a quick drawing without having all the floors accurate but the door always stay at the bottom of the wall. How to overcome?
ALSO Sometimes garage doors don't go to the bottom of the wall and they won't move either. What gives? confused.gif" border="0
Are you aware about the 'Height'field in the
objectinfo? Select your door and type in the value you want. Also if the door is a symbol you can edit the symbol and move the door up. In this case all inserted instances of the symbol in the drawing will change it's z- position.
HTH,Hannes
