ErichR Posted March 6, 2002 Share Posted March 6, 2002 We're still not able to resolve the problem below, posted earlier: We've had tear-your-hair-out sort of text problems on two diffent PCs running VWA on two different files. This isn't a class visibility problem. Text is visible on the screen, but will not print. Text in some fonts will print, but not in all. For some reason the text changes from Times New Roman to Tiepolo Book, which is visible, but won't print. We couldn't change it to Times New Roman, which we knew would print. Through trial and error, in the font window, we found that you have to select text one line below the font you want in order to get the font you want! This has got to be a bug. Quote Link to comment
VulcanGrip Posted March 6, 2002 Share Posted March 6, 2002 Hmm, that sounds like what was happening to me when I first upgraded to VW 9. (text not printing) I am on a G4 mac though. I believe it turned out to be a preferences corruption issue. I thru out the program and reinstalled. This worked for me GL Quote Link to comment
ErichR Posted March 7, 2002 Author Share Posted March 7, 2002 But this problem is on different PCs and different files. And it appears to be the same problem as is being discussed in the General Discussion Group regarding Callout Text Boxes. Quote Link to comment
