Nico vd Schaaf
SET WS subrow value
Hi,
I've found a node that can get a subrow value (of a database row). Now I'm looking for a node that can SET a subrow value. Does it exist?
I've got a worksheet that counts symbols per space object. But I want the number to appear in a space label. Currently I use 2 WS to fix this: 1 WS that counts the symbols per space object and a second WS that just lists the space objects in which I manually type the symbol count (as shown in WS1) so it appears in the space label.
I was hoping that Marionette could automate this process for me.
Nico.
Subrows are calculated based on criteria, so the way to do this would be to modify the data attached to the item the subrow is referencing.
Which field do you use when adding the count data to the space object?
Hi Marissa,
Thanks for thinking along with me!
I'm using the no. of occupants field ('Space'.'11_Number of Occu'). I guess you'll need to grab both the 'count' and the object ID from a particular row and combine them in order to add the correct count to the correct space object?
It also would be nice to recalculate the WS that counts the symbols. I guess for this action a node is also needed?
Regs,
Nico
