Andrew Mac Posted February 28, 2002 Share Posted February 28, 2002 I have Vector works Architect 9.5 and when i design some that has curves to it and render it, the curve lines are not very smooth. I've tried setting verctwork perferences tp very high for both 2-d and 3-d. What elso can be the problem? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted February 28, 2002 Vectorworks, Inc Employee Share Posted February 28, 2002 If you're using OpenGL rendering, set the Detail level to High or Very High in the OpenGL Options... command. If you're using RenderWorks, do the same with Custom RenderWorks Options... This should do the trick. Quote Link to comment
