willofmaine
The Mystery of a Rectangle's Width and Height
I've run a worksheet report on rectangles.  One of the rectangles (on an angle) is 19' wide by 1' high.  I know it's so because the OIP says so.  But the report returns the rectangle's 1' height as its width.  Why?!?!?!?!?!  Why are a rectangle's width and height such a mystery to Vectorworks?  Why does EVERY new thing I attempt in Vectorworks represent inexplicable difficulty and the need for a workaround or two???
9 answers to this question
Yes, while VW has some great features, it is riddled with these behaviors which seem designed to send you to some other software.
Yep; more and more I find myself seeking an alternative - something with all the great features and the rich promise of Vectorworks... but without the endless array of crippling issues.
In reports (worksheets). width is not actually width, but rather the X dimension of the bounding box (might be different for rectangles) while Height if the Y dimension of the bounding box.
The OIP is much smarter than the worksheets.
@Pat Stanford apart from rectangles, which worksheets really do take the width and height from the object (it seems). @willofmaine"s rectangles are at an angle and I'm getting the same results.
The Object Information Palette of Rectangles swap the Width and and Height fields around when rectangle goes past a 45° rotation. This function is just not picked up by the worksheet. Frustrating.
I think this is a bug.
  • Like 3
Just gunna say that is a very sad song you're singing there @Pat Stanford.
@markdd If you think it is a bug, then make sure you submit it. This it the kind of thing that rarely gets submitted and therefore rarely gets fixed.
A long time ago I had a vision that I could pull length and width of my 3d rectangles that I used for print graphics on set models, and put them on a worksheet for a graphics schedule.  I worked with a VW trainer to set this up, and then we both came to the conclusion that the worksheet data is only accurate when pulling that information in a Top/Plan view.  If the rectangle was in any other orientation, the data would be inaccurate.  Such a pity.
It seems Vectorworks' understanding of Rectangles and Spaces is backwards.  If only they were switched around...  VWIS211:
