Accessory Stacking
Hi there-
I'm finally getting around to exploring VW2021, and I'm having an issue with Accessory stacking in 2D view. I've inserted a floor plate accessory for a light, but it stacks above the light. (See attached). Back in the day I would just select the accessory and send it backward. Now that option appears unavailable, even in the new "Edit Accessory" mode. Any wise ideas?
Much thanks!
Guest Frank Brault
Although not in the realm of standard support for send-to-back,  perhaps in this case, selecting the other symbols and choosing cut and then paste will set the desired order.
