This hardscape slab keeps grabbing something on the base plain. I have cleared out all original line work and recreated my geometry several times. I used the grade tool to set the new slopes in aligned slab modifier top mode. This is when the problem happens. In I also did a couple test samples on a clean document with good results. I'm looking all over for a bottom datum setting or an elevation offset. Any ideas on what is causing this would be much appreciated.
Landartma
0 answers to this question
