Landartma Posted February 24, 2021 Share Posted February 24, 2021 I'm trying to edit a surface modifier but when I get into the edit window none of my graphics are showing. What am I missing? Quote Link to comment
zoomer Posted February 24, 2021 Share Posted February 24, 2021 (edited) There is a Setting in VW Settings, or in Quick Settings Bar (top right directly above drawing) which you can pull out from the little arrow. It switches visible environment elements, when in an Edit Mode, on or off. If this does not help, it would be the same problem as for Slab's Edit Mode, which isn't able to do so, unfortunately. Edited February 24, 2021 by zoomer 1 Quote Link to comment
Landartma Posted February 24, 2021 Author Share Posted February 24, 2021 Thanks Zoomer. Tools-Options-Preferences-Display-Show Other Objects When in Editing Mode. 1 Quote Link to comment
Poot Posted March 16, 2021 Share Posted March 16, 2021 On 2/24/2021 at 6:31 PM, zoomer said: There is a Setting in VW Settings, or in Quick Settings Bar (top right directly above drawing) which you can pull out from the little arrow. It switches visible environment elements, when in an Edit Mode, on or off. Thanks @zoomer! Both editing the display options in preferences, and the quick menu work! Quote Link to comment
