sstanelle
Export multiple symbols as a single image
Hi,
I wrote the following Python script that finds the first symbol in the active layer, creates an image from the symbol, and then exports the image to a file. This works very well. However, if I try to do something similar with a group containing multiple symbols, the call to vs.CreateImgFromSymbol returns None. This makes sense to me as the name, vs.CreateImgFromSymbol, would seem to imply a symbol rather than a group containing multiple symbols is required as a parameter. My question is whether it's possible to write a python script to export multiple symbols, either grouped or individually, as a single image file. Based on what others on this forum have suggested, I had started to investigate creating a viewport on the active layer and exporting the viewport as an image, so far to no avail. Before I spend more time on the viewport route, I wanted to get some input on whether a viewport is even a viable solution or if there is some other method of exporting multiple symbols as a image.
Many thanks in advance,
Scott
import os
hObj = vs.FInLayer(vs.ActLayer())
if hObj == None:
    vs.AlrtDialog("hObj is null")
else:
    inSymName = vs.GetSymName(hObj)
    symWidth = vs.HWidth(hObj)
    symHeight = vs.HHeight(hObj)
    vs.AlrtDialog("hObj: " + inSymName + ", Width: " + str(symWidth) + ", Height: " + str(symHeight))
    imgObj = vs.CreateImgFromSymbol(inSymName, symHeight * 300.0, symWidth * 300.0, 0, 3, 0)
    if imgObj == None:
        vs.AlrtDialog("imgObj is null")
    else:
        filePath = os.path.expanduser("~") + os.path.sep + "Downloads" + os.path.sep + inSymName + ".png"
        vs.ExportImageFile(imgObj, filePath)
Maybe create a temporary symbol > add all other symbols in there > place on drawing > export as image > delete temporary symbol
twk,
Thank you very much for your response and for your solution. This worked great! I can't believe that I didn't think of this obvious and simple solution. 😄
Regards,
Scott
