Create Viewport Script Keeps Crashing Vectorworks
MTRobin
Hi Everyone,
This script keeps crashing Vectorworks when I execute it. I have it as a custom plugin, assigned to a menu drop down, and typically recall it through a hotkey. I tried isolating the line that is giving me issues by commenting out all the others and it looks like the "Create Viewport" command is the culprit. I also tried adding wait commands at different sections of the script and that didn't help either. I was hoping someone could help diagnose what I am doing wrong.
The script is designed to turn off dark background, turn off layer colors, change the layer options, set the render mode to wireframe, and then create a viewport and open the viewport dialogue window.
SetPref(16, FALSE);
SetPref(11, FALSE);
SetPrefint(506, 3);
DoMenuTextByName('Wireframe Render Chunk', 1);
DoMenuTextByName('Create Viewport',0);
Thank you,
Maxwell
Edited by MTRobin
On 2/22/2021 at 6:05 PM, JBenghiat said:
Could you please help me set these up? I don't have much experience with handles. I want to use the handle of the currently selected layer. Pretty much just recreate the DoMenuTextByName commands.
Thank you,
Maxwell
Edited by MTRobin
To create a viewport on the current layer, the script is as easy as:
viewHand:=CreateVP(ActLayer);
The viewHand variable (or whatever you want to call it) is a handle to the viewport so that you can set crop and visibilities using SetVPCropObject, SetVPClassVisibility and SetVPLayerVisibility.  The ActLayer command will return the handle to the currently active layer.
Thank you. I got this to work, but it's not quite what I'm looking for. This creates a Viewport on the current layer, but what I am trying to achieve is to open the "Create Viewport" dialogue to place a viewport on a sheet layer.
Thank you,
Maxwell
Vectorworks does create a .dmp file when it crashes as well as a log file (my current log file for VW2019 that I use every day is currently 56,000 lines long, but is timestamped per line, so if you know when you crashed, you should be able to find some information).
On Windows, it is stored in your User Folder.  So if you go to Tools - Options - Vectorworks Preferences and go to the User Folders tab and click "Explore" (or "Open in Finder" on Mac), it should open up the location of the logs.  You will probably have to send the .dmp files to VW to get answers unless you have a debugging program that can open them and are comfortable with navigating them.
