Thomas Peters 7 Posted February 19 In the interest of accommodating all unit preferences, I've made sure to use dim nodes for all dimension values. So far this works perfectly if I change unit preferences inside of my working document. If I create a new imperial document, I can import and operate these object nodes perfectly. If I create a new metric document, they do not even appear on the design layer, and the Shape pane in the OIP shows me nothing aside from that there should be 'something' there... I'm inserting some hybrid symbols and manipulating their z height. There isn't very much to the network at all. Is anyone able to reproduce this? Any advice would be appreciated. Stand Hollywood Combo Triple.vwx Quote Share this post Link to post
m.graf 33 Posted February 21 Hello Thomas Peters, I changed your script a little, now I think it works. Greatings M. Graf Stand Hollywood Combo Triple.vwx Quote Share this post Link to post
Thomas Peters 7 Posted February 21 Thank you @m.graf, the only difference I can see is that you've drawn a wire from the resultant object to the dummy node at the end? This does" tie the room together" nicely, but if I import the red symbol from the Resource Browser in your file into a new Blank (metric) document, it still doesn't appear when insert it. See attached screen recording. If it's in a document and it works then it works perfectly, it's getting it into the document that's giving me trouble. Thank you also for your other contributions to this forum, I'm currently using parts of your Object Builder network to read worksheet data for my next Marionette project. mystery symbol.mov Quote Share this post Link to post
m.graf 33 Posted February 21 Hello Thomas Peters, okay now i see the problem. I'll check it out in the next few days. Your script may have problems finding the symbols in the library. Greatings M. Graf 1 Quote Share this post Link to post
m.graf 33 Posted February 21 no problem - only copy the marionette from file to file... without the Symbols. Greatings M. Graf Bildschirmaufnahme 2021-02-21 um 17.50.31.mov Quote Share this post Link to post
Thomas Peters 7 Posted February 21 Thank you- Yes, I can reproduce that. I don' throw this term around lightly, but I do think then there's definitely a reproducible bug here? Specifically, a but that affects documents started with metric units. Do you agree? Quote Share this post Link to post
m.graf 33 Posted February 21 I do not know yet... have you tried to create a new intelligent symbol from my slightly modified marionette object and to import it? Greatings M. Graf Quote Share this post Link to post
Thomas Peters 7 Posted February 21 Yes, if by intelligent symbol you mean a red symbol? As someone with some experience in defining bugs, I don't like using the phrase 'it does not work' in this context, but I do hope I have been clear with my description of the issue? If I have been vague or unclear anywhere, please let me know. If I create a new red symbol in your document and import that into a new imperial file, it does work. If I create a new red symbol in your document and import that into a new metric file, it does not work. (Does the German language version even have an imperial option?) If I paste the marionette into a new metric file and then create the red symbol in the new document, it does work. Posts like these have helped me learn just about every tool I know, so I hope this isn't drawn out, and I hope that future readers will benefit from this. 1 Quote Share this post Link to post
m.graf 33 Posted February 21 i think it's a bug... greatings M. Graf 1 Quote Share this post Link to post
Antonio Landsberger 22 Posted February 22 @Thomas Peters Hi Thomas, the issue you're having is indeed a bug, not what you are suspecting though. Not the difference between metric and imperial is at play here, but the scale of the design layer at which the red symbol was created (here: 1/4''=1') and the scale of the design layer you are trying to insert the red symbol. If the two scales are different, all wires within the wrapper are disconnected and thus: no more geometry in the Marionette Object. Long story short: this was reported a couple weeks ago. There's a chance this might be fixed with 2021 SP3 - no promises though. Regards, Antonio 1 Quote Share this post Link to post
