Yonina 0 Posted February 19 Hello guys, I am trying to align my text with the same distance. is anyone having experience in this situation ? as the image I attached, I would like to make A=B=C. Quote Share this post Link to post
Pat Stanford 1,638 Posted February 19 Set the Top and Bottom text blocks where you want them, select all of the text blocks and use the Align/Distribute command and Distribute Spacing. 1 Quote Share this post Link to post
line-weight 859 Posted February 19 4 hours ago, Pat Stanford said: Set the Top and Bottom text blocks where you want them, select all of the text blocks and use the Align/Distribute command and Distribute Spacing. That doesn't work unfortunately because it takes the leader lines into account, so in the OP's example it would place the equal space between the arrow head of the uppermost note, and the top of the text box of the note below it. 1 Quote Share this post Link to post
Boh 507 Posted February 19 (edited) You could set the callouts to have no leader lines then do as Pat suggested then reset the leader lines. But maybe the Align/Distribute callouts tool in the modify menu would do what you want? I think it might. Edited February 19 by Boh 1 Quote Share this post Link to post
drelARCH 62 Posted February 19 It seem to work fine when you select 'insertion point' instead of spacing. No need to hide leader line. At least that is what I see in my set up. Quote Share this post Link to post
line-weight 859 Posted February 19 18 minutes ago, drelARCH said: It seem to work fine when you select 'insertion point' instead of spacing. No need to hide leader line. At least that is what I see in my set up. That'll only work if all your text boxes are the same height. 2 Quote Share this post Link to post
Yonina 0 Posted March 4 yes.... it doesn't work when the text boxes are not at the same height a bit annoying haha i would like to se the space between them the same now i just manually make it the same Quote Share this post Link to post
