I have a problem where the object info palette does not update when I select an object. Sometimes it just starts happening randomly or sometimes it's like that when I first open the file. Often, but not always, it can be cured by repeatedly right clicking on an object until it responds and starts showing the correct info. Also, when you have something selected, it sometimes doesn't update when you change the size of something in the drawing, which can lead to problems if you then try the +5mm trick in the width or height fields as it adds 5mm to the old values not the new ones and then resets the object in the drawing to the wrong size.
Will
1 answer to this question
