Area Calculation
Davide
Net Area Polys creates "net" room area polys from the walls on the active layer. Not a bad trick, but not what you were looking for ;-)
To create a report of polygon areas, you must first create a database of all the polygons of interest. See the VW9 manual beginning page 16-13 to see how to do this. Use a criteria [T=POLY] for all polygons in the file, or a criteria [T=POLY AND L=<<LAYERNAME>>] for all polygons on a particular layer. (See the section in chapter 16 on Search Criteria.) Then, to return the area, go to the database header row and in the column you wish, type =AREA . That's it. I know this isn't simple to learn, but once learned, it's very simple to do.
