Mark Aceto 453 Posted February 15 (edited) I’m working with a client who has a Fundamentals license. I have a Designer license. When I go to my Fundamentals workspace, are the same features missing for me that are missing for them? I need to clearly understand what the limitations are on their end for frustration-free collaboration. Thanks! Edited February 15 by Mark Aceto Quote Share this post Link to post
Pat Stanford 1,634 Posted February 15 Yes, the menu commands and tools that you see in the Fundamentals workspace are the one's they have access to. The thing to look out for is that if you use PIOs that are not included in Fundamentals you will be able to edit them (since your license is actually Designer) while they will be "read only" proxy objects for the user on Fundamentals. If you need a "fool proof" (remember they always make a better fool) way to check, you can create a script with just the following line: DisableModules(1); That should make your version think it is Fundamentals and Renderworks only. To undo this you will have to quite and restart VW. 1 Quote Share this post Link to post
P Retondo 112 Posted February 16 The other thing you can do is have your client email you their workspace settings file (.vww file). Rename it to something distinctive, enable that, and you should have only their workspace and all preferences for shortcuts, etc. 2 Quote Share this post Link to post
Pat Stanford 1,634 Posted February 16 Even if you are using their workspace, you may still have access to PIO settings that they might not have if you don't do the DiableModules thing. 3 Quote Share this post Link to post
P Retondo 112 Posted February 16 4 minutes ago, Pat Stanford said: Even if you are using their workspace, you may still have access to PIO settings that they might not have if you don't do the DiableModules thing. I defer to Pat's superior knowledge. But, if your client has customized their workspace, having their actual .vww file will make your interface identical to theirs, as an added measure to Pat's Designer disabling script. 1 Quote Share this post Link to post
Pat Stanford 1,634 Posted February 16 @P Retondo I completely agree that having a copy of their workspace is a great idea. Especially if you are going to have to do tech support on how they need to accomplish things. I just wanted to make clear that the workspace if only 90% of the issue about seeing what someone on a different version can do with a drawing. 1 Quote Share this post Link to post
Mark Aceto 453 Posted February 16 @Pat Stanford and @P Retondo thanks so much! Question: after following both of these steps, would it be possible for me to export a custom Fundaments workspace from my copy of VW that they could import? When we did a screen share, it looked like theirs was all out of wack. No access to Layers in the Nav palette (even from the Menu bar)… I would love to customize it for them by turning on layer scale etc. I’m also afraid this is headed towards a user folder dump, and I’m really trying to sell them on VW without frustrating them with too much tech support. They’re coming from SketchUp and Cinema. Quote Share this post Link to post
Pat Stanford 1,634 Posted February 16 Yes, you should be able to send them workspace. Or just have them open the Workspaces dialog box and see if they are running a stock workspace (saved in Applications folder) or a custom workspace (saved anywhere else). If it is a custom with a stock name, they should Duplicate it under a different name and then delete the version in the User Folder. That should get them back access to the stock version. They may have really messed up and saved a custom workspace in the Applications folder, but it would have been a manual thing. VW has not done that for a long time. 1 Quote Share this post Link to post
P Retondo 112 Posted February 16 The Navigation palette is not part of the Workspace. Sounds to me like you should start out by having them uninstall then reinstall Vectorworks to get a fresh start. 1 Quote Share this post Link to post
Mark Aceto 453 Posted February 17 @P Retondo I was realizing that as I thought through the conversation here… Think I’m gonna have to wait until we’re face to face mask to mask again to provide that tech support. Quote Share this post Link to post
Andy Broomell 1,154 Posted February 17 The Navigation Palette simply doesn’t exist in Fundamentals (unless that’s changed in the last couple years). 1 Quote Share this post Link to post
