LeeElston Posted February 15, 2021 Share Posted February 15, 2021 In the Space tool, I can define room finishes from a drop down menu, linked to a .txt file in the application... Can I change the file this is linked to, or would I have to copy information in an other document into the ones embedded in VW? The standard ones are presumably a US imperial spec and not particularly relevant for UK. I appreciate I can edit this from inside the finishes page, but might be useful to refer to a different spec note document (word or notepad?) Quote Link to comment
Tom W. Posted February 15, 2021 Share Posted February 15, 2021 (edited) You would have to convert your specs into .txt files + save them in the 'Space - Room Finishes' user folders. There are separate ones for 'Base', 'Ceiling', 'Floor' + 'Walls' so you'd need a .txt file for each. If you had a long list of finishes this would probably be more efficient than doing it through the 'Edit Room Finishes' dialog but not quite as simple as importing a pre-existing word/notepad doc... I haven't tried this by the way! Edited February 15, 2021 by Tom W. 1 Quote Link to comment
