Every so often I encounter this pop-up when trying to delete a class, and have never really understood the context of why it sometimes appears and sometimes doesn't.
The message seems to suggest that the class is being used by a Plug-in Object, but I know this isn't the case because typically it's a class I've made myself and it hasn't been used in any special way.
Today I finally realized the circumstances that cause this pop-up: objects in that class are being cut through in a Section Viewport.
(Regarding the text of the pop-up... perhaps a Section Viewport is technically considered a PIO? But I wouldn't have assumed so).
As it stands, I doubt a typical user understands what this pop-up means or what to do about it. It should be solved in one of two ways:
1. Make it so that you can delete these classes, and it would brute force delete the objects even if they're being cut through in the Section Viewport.
-or-
2. Alter the pop-up to better describe why the class can't be deleted, such as specifically saying it's because of a Section Viewport.
Note that this only applies when trying to use first option shown below, not when reassigning objects to a different class which is always possible but not the goal:
Andy Broomell
-or-
VE-101608
9 answers to this question
