taliho 5 Posted February 12 HI- To model a barrel vault, I went to front view, drew an arc, offset and closed open curves extruded. What i got was a segmented barrel vault...... What settings do I need to show it as a smooth arc in section (hidden line) and interior renderings? Thanks Quote Share this post Link to post
Pat Stanford 1,534 Posted February 12 Go back to the original arcs and check your 2D and 3D conversion resolution in Vectorworks Preferences. Set to Very High you will end up with 256 segments that should be smooth enough for most uses. If you need it to be even smoother try using a NURBS Curve and Lofting instead of extruding. Quote Share this post Link to post
EAlexander 261 Posted February 13 You could also build this as a sweep and that would let you adjust the segment angle, so you can control the "resolution" of the arc. Lower number = smoother curve. Quote Share this post Link to post
taliho 5 Posted February 14 Thanks both- I changed to Very High setting which worked great Tali Quote Share this post Link to post
