Jan H Posted February 8, 2021 Share Posted February 8, 2021 Does anybody know what these grey frames are in the plan view from parametric unstyled doors? Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted February 8, 2021 Vectorworks, Inc Employee Share Posted February 8, 2021 My guess would be the Threshold. Try deselecting it in the Object Info palette. Quote Link to comment
0 Jan H Posted February 8, 2021 Author Share Posted February 8, 2021 Matt, thanks for your help...but unfortunately this is not the the threshold .... Matt, Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted February 8, 2021 Vectorworks, Inc Employee Share Posted February 8, 2021 Can you attach a simple file showing the issue? Maybe copy a wall with one of the doors in it and paste it into a new empty file and attach it? Quote Link to comment
0 Jan H Posted February 9, 2021 Author Share Posted February 9, 2021 @ Christiaan....unfortunately that's not the problem 😞 @Matt Panzersee file attached ..thanks so much for your help. door lines problem.vwx Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted February 9, 2021 Vectorworks, Inc Employee Share Posted February 9, 2021 OK. There were a few things going on and here's what I did to fix it: The door is inserted on the left edge of the wall. Typically they should be inserted on the wall Center Line.The Fix: - In the Object Info palette for the Door, set the Insert popup to "Center Line". - When you do this, the door will shift and you'll need to change the Offset in Wall to compensate. - When the door shifts back in place, the interior trim Thickness will be incorrect. You'll need to change that to zero. Now, those lines you were talking about are header lines. They are created by the door for making ceiling plans for Top/Plan view. These should be placed in a class that can be turned off for floor plans and turned on for ceiling plans. To set this, open the Door Settings dialog, go to the 2D Visualization pane, and set Header to a class that can will be turned off for floor plans. In the video, I set it to the default of "Ceiling-Main". ScreenFlow.mp4 2 Quote Link to comment
0 Jan H Posted February 9, 2021 Author Share Posted February 9, 2021 amazing ! thanks so much ! this makes my day! I was searching for hours .... 1 Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted February 9, 2021 Vectorworks, Inc Employee Share Posted February 9, 2021 Glad to help, Jan! If you haven't already, I think you'll find these forums a great place to get help. 🙂 2 Quote Link to comment
0 Tom W. Posted February 9, 2021 Share Posted February 9, 2021 @Matt Panzer just out of interest is the O.I.P. the only place you'll find the 'Insert' setting + under what circumstances would you change it from the default 'Centre Line'? I don't think I've really noticed it was there before...! Thanks 1 Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted February 9, 2021 Vectorworks, Inc Employee Share Posted February 9, 2021 11 minutes ago, Tom W. said: @Matt Panzer just out of interest is the O.I.P. the only place you'll find the 'Insert' setting + under what circumstances would you change it from the default 'Centre Line'? I don't think I've really noticed it was there before...! Thanks All wall insertable symbols and plug-in objects have this option in the Object Info palette. A Plug-in object definition defines the default insert location - meaning the default setting is buried within the Plug-in Manager dialog. Note: It is not recommended that users change this default because the setting will likely revert back after installing a service pack. For Doors and Windows, I don't think you would ever want to change it from Center Line. There may be some use cases out there, but I cannot think of any at the moment. Quote Link to comment
0 Tom W. Posted February 9, 2021 Share Posted February 9, 2021 Ok thanks in that case I'll continue to ignore it! 1 Quote Link to comment
Jan H
11 answers to this question
