Visibility in open GL
Landartma
I inserted some new windows in the model and they seem to show fine in wire frame not in Open GL.  The original windows appear as they should.  However, the original door does not.  The only setting changed was on the second floor slab.  It was switched from manual bounding to auto bounded.   What's the setting i'm missing here.  I am also having the same issue on the back wall as you can see.
1 answer to this question
