Ross McLee Posted February 3, 2021 Share Posted February 3, 2021 Hi all, I was after some advice on best working method for drawing an installed distributed audio systems (PA) for buildings. I'm trying to avoid taking up huge amounts of drawing space showing hundreds of loudspeakers (lots of 100V line) all of the same type, which is not very meaningful, but I still want to schedule the quantities and locations etc. Any best working methods, welcome! Thanks, R Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted February 3, 2021 Vectorworks, Inc Employee Share Posted February 3, 2021 I guess you could do the schematic as an abbreviated version like Speaker 1 ... 100. You know dotted lines. What you really need is to put Equipment Items on floor and reflected ceiling plans. So you could create a symbol that looks like your speaker. Create an Equipment Item and then select Use Symbol in the Object Info Palette and select your speaker symbol. That gets you and Equipment Item that looks like your speaker. Duplicate this and rename it to create all your speakers and place them on the plans. Use Create Report menu to get a report of Equipment Items. Just my 2c worth Conrad 1 Quote Link to comment
Ross McLee Posted February 3, 2021 Author Share Posted February 3, 2021 So create a report on "equipment items" instead of "devices" .. ! that would work. Not sure how I would sync the quantites of equipment items to the label in the schematic automatically, if the design changes. But I'll give it a go. Thanks CP. Quote Link to comment
