Pumpkin 0 Posted February 2 Hello Vectorworkist, First post around here ! I am trying to obtain a list of Symbols according to criteria present in their Records Fields. Knowing that the Symbols are not inserted in the drawing ; but they are obviously present in the Resource Manager. We work with products to which accessories can be added. The main idea is to be able to display a Popup List in the OIP of our products including compatible accessories. The Symbol accessories would contain Record Fields to verify their compatibility with the products. Currently, we cannot find a node (or several) allowing to retrieve the Symbols present in the Resource Manager and, then filter them. If you had the solution (or a starting point) ! Quote Share this post Link to post
Pat Stanford 1,526 Posted February 2 Criteria (at least in worksheets) only function on objects that are in the drawing. I don't think you are going to be able to do what you want the way you are trying to do it. In Vectorscript there are functions to get a list of Resources in a file. You could then filter that list based on the field values to get the list you want. You may have to look into writing a custom Marionette node to do what you are looking for. Quote Share this post Link to post
Peter Vandewalle 38 Posted February 2 As Pat said, you’ll have to create a custom node to achieve that, but it should be possible. Quote Share this post Link to post
Pumpkin 0 Posted February 3 Thanks for your feedback. This next step will be a deep one ! Quote Share this post Link to post
Antonio Landsberger 22 Posted February 3 Hello @Pumpkin welcome to the Vectorworks forum! If you want to get to the interesting point of your requirement, you can start with this: This already does the first part for you: lookup and list all symbols that are in a specific folder showing up in a nice little dialog. Now you just have to figure out the second part: filtering the list of symbols using the criteria specified by you. Good luck! Regards, Antonio Quote Share this post Link to post
