Displaced wall
Landartma
3 answers to this question
I would try :
Menu > AEC (or Architecture) > Delete Wall Peaks
whenever Walls Top or Bottom Heights don't look reasonable
according to their settings.
But in this case, I think it is just that the Door is too large
for the Wall. It's height will cut the Wall through,
from top to bottom.
VW Walls can't stand that. Or can't deal with it.
Edited by zoomer
I thought the size might be an issue so I removed the details like lintel and trim and it still did it but I will check height.  I removed wall peak so we will see  if that helps.  I was able to simply use the reshape tool and drag it back into place but then had to use the wall join tool to connect at the corner.  Here is the front view.
