I have an issue regarding the Cut Plane and Display you can find by right clicking a section VP and choose Edit Section in Place.
I have trees. Some trees are cut by my Section Line. I don't want them to be cut. How to achieve this ?
I have done two things :
1) Watched @Matt Panzer video for the correct procedure :
On 4/18/2019 at 3:11 PM, Matt Panzer said:
Try this: 🙂
2) Done this test which confuses me :
The trees are VBvisual plants. I copied the Tree n°1 five times. Trees n°1-3 are on the Section Line. Trees n°4-6 are behind the Section Line.
Tree n° 1 is what I want to avoid. You can see little section lines you don't want to get. The tree has also less leaves because they are logically removed by the Cut Plane.
I want my trees n°1-3 to look like my trees n°4-6 even if they are cut by the Section Line.
The settings of Trees n° 2 and n° 3 don't seem to solve my issue.
If I may also summon @Christiaan and @zoomer to ask you how you would solve this issue and more generally, how do you deal with trees ? I would appreciate your help.
Stéphane
Hello.
3 answers to this question
