hollister design Studio Posted January 28, 2021 Share Posted January 28, 2021 This has happened a couple of times in the last month and I finally recorded it to ask you all what is going on. The clip cube is NOT turned on. error - No Clip Cube.mp4 So in the video I'm using the flyover tool to tumble and anything that is to close is cut off. If I zoom in nothing is visible. In Maya this happens when you have the near plan of the camera set at to great a number. But I don't know how to adjust the main screen camera settings so I'm not sure what I did to have this happen. I've 'save as' the file (so I don't mess with my main file) and restarted VW and everything looks good - but what just happened? What am I doing? Help! Quote Link to comment
0 zoomer Posted January 28, 2021 Share Posted January 28, 2021 Seems like your geometry is too far from internal origin ? 1 Quote Link to comment
0 hollister design Studio Posted January 28, 2021 Author Share Posted January 28, 2021 @zoomer it is pretty far from the origin. I'm using the survey file I got form the surveyor to locate everything - so the origin is actually down the block a bit from this project. If I need to "center" the project I will. But even so, why are the only visible objects the ones that are the furthest away from the origin? After restart everything looks fine again. Is it just a VW hiccup - or did I key something wrong? 1 Quote Link to comment
0 hollister design Studio Posted January 28, 2021 Author Share Posted January 28, 2021 Here is a top/plan with the show page boundary on: And Here it is just rotated up so you can see where the origin is: Can I manually reset the origin? Quote Link to comment
What am I doing?
Help!
3 answers to this question
