Kevin K 182 Posted January 28 I don't indulge too heavily in using either of these formats, but I am assuming that, for example, if you import an ifc file, it may look ok, but is mostly worthless because ifc walls are not VW walls, ifc windows and doors are not VW doors and windows, etc, etc. am I missing something in relation to converting IFC Data into VW parlance ?? Quote Share this post Link to post
Wes Gardner 334 Posted January 28 @Kevin K - agreed..however, the intent is often not to use the IFC object directly, but to use it for comparison/clash detection. Wes Quote Share this post Link to post
Kevin K 182 Posted January 28 Wes, that is a valid point. Use it as a reference. Quote Share this post Link to post
elepp 92 Posted January 28 Iirc it's just not there yet, but the future versions of IFC should be able to do that. IFC 4 has a modell view definition that is called "design transfer view". It's not yet supported by Vectorworks but it should work in that direction. Quote Share this post Link to post
Kevin K 182 Posted January 28 @elepp Well, that does sound promising!! 1 Quote Share this post Link to post
Michal Zarzecki 46 Posted February 9 Hi guys. I wanted to give it a try and see how one of my projects would look exported to IFC. I ended up with a large file which I struggle to import anywhere. I followed the set up described on the hep pages, but perhaps there is more I need to take into account. Would you be able to direct me where I can find some more guidance and understanding of the settings? Quote Share this post Link to post
Boh 505 Posted February 9 (edited) Yes i'd be interested to know more about working with ifc in vectorworks. VW help is a bit slim on the issue. @Michal Zarzecki I looked at some of my recent ifc exports and they are not that big. A 70Mb vw file exports to a 20Mb ifc. Maybe play around with the export options in the Export IFC Project settings. I just have it set to "Export Custom Property Sets" which I think means only stuff with IFC data attached. i.e. parametric objects like walls, slabs etc. If I have extrudes in the file I want to export to ifc I add an IFC record to it otherwise extrudes won't export. Edited February 9 by Boh Quote Share this post Link to post
elepp 92 Posted February 9 @Michal Zarzecki @Boh I also only have rudimentry understanding of IFC in Vectorworks. Usually IFC-files should be much smaller than vwx-files. If you need them even smaller you should give ifcziop a try. This file type is very suitable to compressions. Ifcxml tends to make files bigger. A few programms prefer xml over standard ifc, for example programms for quantity take off and cost calculations. Since the introduction of ExportOptions in the Datamanger, these options here are not so useful anymore. The checkboxes here treat all objects the same, but you might want to treat every ifcobject differently. So Walls by components but not slabs. The checkbox for "Quantity Take Off" is used if the recieving software can't calculate quantities from the objects themselves. The Solibri Model Checker is calculating its own quantities. These are just a few things I have picked up over the years. If you have more questions, feel free to ask. Nevertheless I would like to have a comprehensive webinar from Vectorworks regarding the use of IFC. There is always more to learn. Wish you a nice evening from Germany. 1 Quote Share this post Link to post
Wes Gardner 334 Posted February 9 Hi All, Here's some information regarding working with IFC and Vectorworks. https://university.vectorworks.net/mod/scorm/player.php?a=52¤torg=articulate_rise&scoid=104 Here's a model containing an IFC file, check out the model set-up https://university.vectorworks.net/mod/page/view.php?id=1407 Here's some more information about working with Vectorworks and IFC https://university.vectorworks.net/mod/scorm/player.php?a=393¤torg=articulate_rise&scoid=786 1 Quote Share this post Link to post
Michal Zarzecki 46 Posted February 10 Thanks, @Boh My file is over 50 MB whilst the ifc ends up as 150 MB, so there must be something seriously wrong there. Do I need to attach IFC to all objects I need to export? These are mostly walls, some custom-modelled objects, plants, slabs and the site model. I tend to assign most objects to Site storey whilst a roof terrace I have in this project is in Storey 1. I will have a look at these resources @Wes Gardner posted. Quote Share this post Link to post
Wes Gardner 334 Posted February 10 @Michal Zarzecki Solibir Model Viewer (a free resource available on both Mac and Win) can be used to validate and varify your model for IFC export. Typically, items such as windows, doors, walls and slabs in Vectorworks are IFC compliant (meaning they have IFC data already attached). Custom modeled objects will need to have IFC data attached or they will not show up in SMV. Wes Quote Share this post Link to post
