RJenni 0 Posted January 27 (edited) I'm looking for some advice on lighting a render. I work in retail and need to do quick renders to show how product would be displayed. A lot of these renders are only one wall. The light always lets them down as they don't look realistic. I need to show ambient lighting or spotlights as well as some feature lighting. Would this be because I am not closing the area off (with 4 walls) or is there certain tips I could use to enhance the way I am lighting. In the images shown it's almost like a grey film over the top and they don't seem as sharp as they shoud be. Any help would be much appreciated. Edited January 28 by RJenni Quote Share this post Link to post
RJenni 0 Posted January 27 (edited) I've managed the under shelf lighting but had to leave the spotlights out as it was throwing the brightness off. Also the lightbox on the backwall was hard to achieve as I had to put the image on in photoshop after I had rendered but it should really have more of a glow. Edited January 28 by RJenni Quote Share this post Link to post
Kevin Allen 258 Posted January 28 Well, the lightbox, I wouldn't use lighting as much as a glow texture on the image. Similarly, I would add a white glow texture to the downlighting in the ceiling. In this case, the texture would have "cast Shadows" turned off so that the VWX lIght Objects above could pass through. 2 Quote Share this post Link to post
Kevin K 157 Posted January 28 @RJenni Yeah, Kevin Allen is spot on suggesting simply adding a 'glow' to the texture. It works wonders when using recessed lighting in ceilings, etc. I use it often in my renderings. 2 Quote Share this post Link to post
Kevin K 157 Posted January 28 @RJenni Also, sometimes the output resolution for a particular sheet layer can make a huge difference relating to your comment about sharpness, etc. Pump that baby up!! Depending, but on sheet layers for an 8x11 page I usually use between 400-600 dpi minimum. 1 Quote Share this post Link to post
RJenni 0 Posted February 3 @Kevin Allen @Kevin K thank you both for your comments. I’ll give the glow texture a try. Also I tried the resolution on another render and that worked a treat. @Kevin K your render looks great. I see a lot of the light would be external sunlight coming in through the glazed roof, would I need to do an extra light source if I turned the spotlights to glow. Thanks! Quote Share this post Link to post
Kevin K 157 Posted February 3 @RJenni Yes, with that particular render, I used a directional light with shadows to get some natural light streaming in from the exterior. Quote Share this post Link to post
Luis M Ruiz 245 Posted February 17 I'd recommend you use a combination of glow textures and spotlight pointing down. Do not fall on the trap of adding a point light, that triggers rays in all directions and your shadows will not look correct. Also, once the render is done, add a little cone of light image (.png) to enhance the effect. Here is a sample. Quote Share this post Link to post
