I'm having a problem with the push pull tool. I'm currently drawing a house in 3d and formed a window opening in the wall. However, when I use the push pull tool to adjust the width and height of the window opening the push pull tool doesn't work. I click the push pull button then drag the surface I'm trying to adjust (like you suppose to) but when I release the cursor the surface returns back to it's original position. What is odd, is that this only happens to a recently created window opening. Also, when I double click the wall to bring up the edit function the adjustment I was trying create appears, but when I click the exit button the adjustment changes back again. It seems as if Vectorworks is operating in an invisible mode - but only the push pull function to a newly formed opening. I'm sure there is a setting somewhere that has been accidently triggered - but I don't know what.
R Emms
Hi,
Edited by R Emmstitle error
0 answers to this question
