Landartma Posted January 27, 2021 Share Posted January 27, 2021 I choose a hatch fill for part of the border of this home and then found a stipple pattern in the resource manager for the other. On the hatch I just choose the boundary and it fills automatically. With the stipple pattern I had to retrace the area for it to fill. I'm a bit confused as to the difference. Is there a way to apply the stipple from the resource manager the same way as a hatch, pattern, tile, gradient or fill from the attributes pallet. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted January 27, 2021 Vectorworks, Inc Employee Share Posted January 27, 2021 The short answer is no - the Stipple has to be drawn. The reason is that it's a parametric object, with parameters that control the randomness, the size, percentage mix and whether it should fade from the edge. So, it has to be applied to a defined shape. You can select a Stipple as a 2D attribute on a Hardscape. Stipples can slow things down a little. You might want to consider making/using Tile fills instead to get the Stipple effect. 2 Quote Link to comment
Landartma Posted January 27, 2021 Author Share Posted January 27, 2021 Got it thanks. 1 Quote Link to comment
