Vectorscript Errors
I am struggling to get this script to work. I was hoping someone could look over my script and see how I can fix these errors.
Thank you!
PROCEDURE LayerOptionToggle;
VAR
LayerOption:INTEGER;
BEGIN
    LayerOption:=GetPrefint(506, 6);
IF (LayerOption = 3) THEN
    SetPrefint(506, 6)
ELSE
    SetPrefint(506, 3)
END;
RUN(LayerOptionToggle);
Edited by MTRobin
Peter is correct. The following compiles and toggles between Show Others and Grey/Snap Others.
VAR
BEGIN
    LayerOption:=GetPrefint(506);
    SetPrefint(506, 6)
ELSE
    SetPrefint(506, 3);
END;
The line before an Else does not need (indeed can not have) a semicolon at the end. Most other lines must have a semicolon at the end.
Even though it is a little more typing, I would probably have written it like this:
VAR
BEGIN
	Begin
		SetPrefint(506, 6);
	End
ELSE
	Begin
		SetPrefint(506, 3);
	End;
END;
That way the lines between the Begin/End pairs alway can have the semicolon and the only one that does not have it is the End right before the Else.
