I'm working with a TD who is using Autocad 2010.
I follow the dialog box in VW to export the file as a DWG compatible with Autocad 2010.
I do a couple of different exports. One set of exports I do my sheet layers Groundplan, Section etc.
The other export I do the design layer that the 3d model of the set was generated on.
When the TD goes to open the drawing I'm told he gets the prompt "File is right protected. Open as read only." He has no choice but to open the file as a read only file and after he does so he can only view the file. He can't even take dimensions.
Any thoughts on what I'm doing wrong in my export?
Adspen84
Thanks.
0 answers to this question
