jcaia Posted September 5, 2001 Share Posted September 5, 2001 I have installed the new VW Architect 9.0.1 - there are lots of improvements, however, there is STILL the delay (working under water feeling) after certain commands i.e. joining, undo etc. When is this going to be fixed? It is really getting old. I am running a G4 400 with 384 megs of ram. Quote Link to comment
jcaia Posted September 5, 2001 Author Share Posted September 5, 2001 I noticed that when i turned VM off it stops doing that.... Quote Link to comment
jfmarch Posted September 8, 2001 Share Posted September 8, 2001 Take a look at my post under General Discussion "VW 9.0.1 Slowness". I've been told by Bruce Fergeson that they are working on it. ------------------ Jim McAuliffe, RA Quote Link to comment
Matthew Giampapa Posted September 14, 2001 Share Posted September 14, 2001 There are a number of things which can cause a slowdown in VectorWorks 9. Mac OS 9.2.1 and 9.2.0 has a bug that when the Mac wakes from sleep it will run very slowly. To avoid this disable power saving so it never sleeps Disabling Virtual Memory has given a slight performance increase to some users. Make sure that nothing else is running in the background which could be holding up the computer If you have a large number of identical plug in objects such as doors or windows, consider turning them into a single symbol with multiple instances. Don't work in a rendered mode while drafting. The solid based renders do not scale linearly with document complexity. Try working in wire frame or OpenGl. Try setting you number of Undos to a lower number. There are also other bottle necks in the program which can only be fix by changes to the software itself. We are working on improving performance in many areas with the 9.5 release. Matthew Giampapa Technical Support quote: Originally posted by jcaia: I have installed the new VW Architect 9.0.1 - there are lots of improvements, however, there is STILL the delay (working under water feeling) after certain commands i.e. joining, undo etc. When is this going to be fixed? It is really getting old. I am running a G4 400 with 384 megs of ram. Quote Link to comment
