Ed Dunn
Allocated Memory
I am working with a 1.5 MB file which keeps asking me to allocate more memory to VA. I am now up to 200MB and it wants more! I have nearly 500 MB of RAM installed. I don't use Virtual Memory as the program slows down considerably. How much RAM does 9.0.1 require?
How will VA for OSX deal with the memory management issue. The main thing I do not like about OSX is the fact that you cannnot turn Virtual Memory off. All I can see is a great loss of speed and premature death of my hard drive. It would be great if the program would be able to turn it off.
G4 450MHZ VA9.0.1, OS9.1,
Ed Dunn
Solar Design &
Construction
Flagstaff, AZ
In what situations are you getting out of memory messages? There is a bogus message that can appear if you are rendering sometimes and you are not set to active layer only.
Virtual memory shouldn't slow you down if you have it set to 1MB over your built-in memory. OSX shouldn't slow you down unless you try to run more things than will fit into your built-in memory.
The warning appears mostly when I am rendering. I usually am in a layer that has 2 or more links.
As far as VM is concerned, VW will run much faster with it off, even when set as you suggest. Also it is nice to not have to wear out the hard drive!
Set your layer options to active only when rendering as a work around. There is a known bug that you can get a patch for by contacting tech support.
Good Luck
Also you shouldn't need your VM. My VW 9.0.1 (w/ RW) allocation is 150 Mb w/ VM off, and I dont have any memory problems.
G4 733
384 Mb Ram
Vm off
Good Luck
The patch for this problem is available from the NNA website under RenderWorks downloads...
Matthew Giampapa
Technical Support
quote:
G4 733
384 Mb Ram
Vm off
Good Luck
