Comparing None (NIL) handles in Python strange error
_c_
I don't understand this.
if I use in an external editor (Visual Studio Code, should that be relevant) this code I get bucketloads of errors:
h = vs.GetCustomObjectPath( gPio_H )
if h is not None:
While the same, expressed with operators, doesn't:
if h != None:
But only in the external editor. In a doc script both forms possible without any problem.
What could cause this?
Please read the Python Programming recommendations:
www.python.org/dev/peps/pep-0008/#programming-recommendations
Quote
Comparisons to singletons like None should always be done with is or is not, never the equality operators.
No, it is definitely weird. I do have it also in the normal VS editor.
This causes errors:
import vs
def LinkIt(obj):
    recH = vs.GetParametricRecord(obj)
    if recH is not None: # uses words
        vs.AlrtDialog(vs.GetName(recH))
def Sub(pt):
    vs.ForEachObjectAtPoint(LinkIt, 0, 0, pt[0], pt[1], 5)
h = vs.FSActLayer
vs.GetPt( Sub )
While this does not:
import vs
def LinkIt(obj):
	if recH != None: # uses operators
def Sub(pt):
h = vs.FSActLayer
vs.GetPt( Sub )
But this never gives problems:
import vs
def test(h):
	if h is not None: # uses words
		vs.AlrtDialog('not NIL')
h = vs.FSActLayer
test(h)
1115646917_Screenshot2021-01-24at12_48_14.thumb.png.329a2356a6cd131bb0f95ea6b18ef46c.png
Edited by _c_
I believe the issue is that the handle is actually a class and not a value, so that indeed it’s not None (the variable is assigned to an object), it’s that the object evaluates to nil. So your line 6 is actually succeeding when it shouldn’t and line 7 executes with a null pointer. I suspect that the internal/external editor difference is a red herring — you were just detecting an invalid object.
The test I use is  != vs.Handle(0), that is, a handle that points to nothing, which is different from a non-existent handle.
It has been said before and it is perfectly useless to say it again, but indeed variable declaration and handling, while less powerful, is clearly a no-brainer in Vectorscript Pascal, while in Python it is a major source of headaches. I can't begin even speaking of how much I miss Vector variables in Pascal. And yes, I am using vector classes in Python.
Rant off. I'll get fit in this fast enough.
Edited by _c_
  • 1 year later...
did you find any conclusion?
actually I tried the following code, understanding that it won't work.
However, I want to check wether the worksheet already exists before I create it.
if worksheet = nil: however doesn't work with a handle, obviously (and "NIL" doesn't exist in Python)
What can I do?
switch back to Vectorscript? 😞
	worksheet = vs.GetObject('WS_TEST')
    if worksheet = nil:
		vs.CreateWS(('WS_TEST'),2,2)
😞 that didn't help
I just want to prevent, that the worksheet already exists before I create a new one 😉
for a in range (4):
#	vs.CreateWS('WS_TEST'+a+',2,2')
	worksheet = vs.GetObject(vs.Concat('WS_TEST',a))
    if worksheet not in [None, 0]:
		vs.CreateWS((vs.Concat('WS_TEST',a)),2,2)
	vs.SetWSColumnWidth((vs.Concat('WS_TEST',a)),1,1,50)
	vs.SetWSColumnWidth((vs.Concat('WS_TEST',a)),1,1,20)
	vs.SetWSRowHeight((vs.Concat('WS_TEST',a)),1,1,20,0,0)
	vs.SetWSRowHeight((vs.Concat('WS_TEST',a)),2,2,20,0,0)
	vs.SetWSCellFormulaN((vs.Concat('WS_TEST',a)),1,1,1,1,a)
1496833676_Bildschirmfoto2022-02-20um23_08_18.thumb.png.9afad571f0355e24da3632ae2855017b.png
create-ws.zip
Edited by matteoluigi
The error is saying your indentations are inconsistent/incorrect.
Indentations are important for python. You must either use 4-spaces, or a single TAB, you can't use both in one script.
try this:
for a in range (4):
Edited by twk
