Dan Parke Posted August 24, 2001 Share Posted August 24, 2001 I am running Vectorworks version 8.5.2. I cannot import drawings from the most recent version of Autocad (I believe it is autocad 2002). Is there an update that can be downloaded? ------------------ Quote Link to comment
Guest Posted August 24, 2001 Share Posted August 24, 2001 There is no update for 8.5.2. VectorWorks 9 should be able to read 2002, and can read 2000. (We haven't done extensive testing with 2002 yet, but haven't found any problems so far.) Quote Link to comment
GJ Posted August 31, 2001 Share Posted August 31, 2001 jodawi- I'm interested in your experience with 2000 translation in VW9. Let's say I'm reticent about the stability of VectorWorks 9, but I'm currently saving many files to R14 and bringing them into Acad2000 for a larger firm that I do work for. Obviously there's still text issues, but what's new in VW9 that would make my life easier? Quote Link to comment
Heather Francis Posted September 17, 2001 Share Posted September 17, 2001 I've spoken to TS about this, and the verdict is, 8.5.2 can only import up to R14, so if you're trying to import newer versions, they probably will not be recognized. Save them as R14, or have whoever is giving you the drawings do the same. Apparently VW9 can take up to 2000 files, but I haven't had a chance to experiment either. Quote Link to comment
Matthew Giampapa Posted September 20, 2001 Share Posted September 20, 2001 Yes, VectorWorks 9 is required if you want to directly import an AutoCADD 2000 dxf or dwg. The real benefit of the doing it in version 9 rather than saving it in r14 format and bringing it into 8 is that the new format actually stores layer scale in a form that VectorWorks can use. No more measuring an object and calculating a scaling factor by hand. Also if you work with others who use AutoCADD 2000, they will have a more seamless time working with documents you send back to them. I'm sure there are other more technical benefits to this as well, but AutoCADD is not a strong subject of mine. Matthew Giampapa Technical Support quote: Originally posted by Heather Francis: I've spoken to TS about this, and the verdict is, 8.5.2 can only import up to R14, so if you're trying to import newer versions, they probably will not be recognized. Save them as R14, or have whoever is giving you the drawings do the same. Apparently VW9 can take up to 2000 files, but I haven't had a chance to experiment either. Quote Link to comment
