Slab and Ceiling: Cut to Walls?
trashcan
Guest Wes Gardner
@trashcan...assuming your walls form a "wall network" (all are joined), you can use the paint bucket mode (Inner Boundary mode) of the Slab tool to "pour" yourself a slab....you can then adjust it for elevation if necessary...I usually do that in a front or side view. Of course, it can be automated by using Layer heights, etc.  You'll probably want to use the same tool for ceilings?
Wes
