Cad coordinates and VectorWork coordinates
Can we export VectorWork file to Autocad then they can right coordinates, I mean, Cad coordinates is exactly when I bring it to Google earth. So how can I do that with Vectorwork - export to Cad ecextly Cad coordinates?
9 minutes ago, Pat Stanford said:
Look up Georeferencing in the help files.
You can define the coordinate (I think of it as the offset) of the file 0,0 point to be the correct real world coordinate.
HTH
But when I Export VectorWork file to Autocad, Its not right coordinates
1 hour ago, Pat Stanford said:
You are correct it won't export the correct coordinates unless you have the file properly georeferenced.
Do you think you have the file georeferenced and it is still giving wrong results?
oh, I think I will try to place the object on a geographic background. Thank you so much!
The other thing I forgot to do in my example file was to run Tools > Origin > User Origin and check the option to Set User Origin to match georeferencing coordinate system. This will set the X and Y coordinates to match the Easting and Northing of the local coordinate system for whichever EPSG code you chose.
This will export DWG with the correct coordinates.
Here's my example updated. Apologies for missing that step!
Monterrey Example.vwx
  • Love 1
this is exactly all I need, I find it while I try export Autocad file by many way. =))) many thanks
  • Like 3
